Manual Testing
This document describes a high-level script of manual tests to check for. We should aim to replace items on this list with automated Spectron test cases.
Image Selection
- Cancel image selection dialog
- Select an unbootable image (without a partition table), and expect a sensible warning
- Attempt to select a ZIP archive with more than one image
- Attempt to select a tar archive (with any compression method)
- Change image selection
- Select a Windows image, and expect a sensible warning
Drive Selection
- Open the drive selection modal
- Switch drive selection
- Insert a single drive, and expect auto-selection
- Insert more than one drive, and don't expect auto-selection
- Insert a locked SD Card and expect a warning
- Insert a too small drive and expect a warning
- Put an image into a drive and attempt to flash the image to the drive that contains it
- Attempt to flash a compressed image (for which we can get the uncompressed size) into a drive that is big enough to hold the compressed image, but not big enough to hold the uncompressed version
- Enable "Unsafe Mode" and attempt to select a system drive
- Enable "Unsafe Mode", and if there is only one system drive (and no removable ones), don't expect autoselection
Image Support
Run the following tests with and without validation enabled:
- Flash an uncompressed image
- Flash a Bzip2 image
- Flash a XZ image
- Flash a ZIP image
- Flash a GZ image
- Flash a DMG image
- Flash an image whose size is not a multiple of 512 bytes
- Flash a compressed image whose size is not a multiple of 512 bytes
- Flash an archive whose image size is not a multiple of 512 bytes
- Flash an archive image containing a logo
- Flash an archive image containing a blockmap file
- Flash an archive image containing a manifest metadata file
Flashing Process
- Unplug the drive during flash or validation
- Click "Flash", cancel elevation dialog, and click "Flash" again
- Start flashing an image, try to close Etcher, cancel the application close warning dialog, and check that Etcher continues to flash the image
Child Writer
- Kill the child writer process (i.e. with
SIGINT
orSIGKILL
), and check that the UI reacts appropriately - Close the application while flashing using the window manager close icon
- Close the application while flashing using the OS keyboard shortcut
- Close the application from the terminal using Ctrl-C while flashing
- Force kill the application (using a process monitor tool, etc)
In all these cases, the child writer process should not remain alive. Note that in some systems you need to open your process monitor tool of choice with extra permissions to see the elevated child writer process.
GUI
- Close application from the terminal using Ctrl-C while the application is idle
- Click footer links that take you to an external website
- Attempt to change image or drive selection while flashing
- Go to the settings page while flashing and come back
- Flash consecutive images without closing the application
- Remove the selected drive right before clicking "Flash"
- Minimize the application
- Start the application given no internet connection
Success Banner
- Click an external link on the success banner (with and without internet connection)
Elevation Prompt
- Flash an image as
root
/administrator - Reject elevation prompt
- Put incorrect elevation prompt password
- Unplug the drive during elevation
Unmounting
- Disable unmounting and flash an image
- Flash an image with a file system that is readable by the host OS, and check that is unmounted correctly
